COOLANT LOW ON MY E320 , please HELP!
ORIGINAL: neox29
hi folks, i bought a 94 E320 , very good condition
but the coolant low light comes on, even though i got it fully refilled
what do yall think the problem is
thanks
thanks
i agree with sleepwalker...
the coolant level sensor is on the coolant fill tank toward the right bottom..looks like a rectangle plug..
the washer fluid sensor is located on the top of the washer fluid container...
Hi Guys,
This car is probably still a W124 and I think that the inline sensors weren't introduced until about 96.
There is a white sensor on the front of the coolant reservoir with a black plug. Try unplugging it and seeing if the light stays out.
If it does, you will need to replace the sensor.
I unplugged the washer fluid connect will that interupt coolant flow? I was cleaning the washer resevoir and didn't have time to put it back is that maybe why my 300E got so hot? And also there is a motor or something in the battery comp. That drops down to the coolant resevoir why might this get hot the lower motor isn't?
MARIODRIVE
Nov 23, 2008 05:39 PM
