Climate Control ! Sleepwalker? Lugnut?
Old Oct 17, 2006 | 01:08 AM
cmackvt's Avatar
Default Climate Control ! Sleepwalker? Lugnut?
Heres one for you. My 1998 E320 4matic 's cabin heats properly after starting and warming up. It warms to the set temp. then the heat shuts off. Outside air then comes through the ducts. Heat only returns if the control is set to Hi. Any ideas? Thanks so much! Chas.
Old Oct 17, 2006 | 04:12 AM
snanceki's Avatar
Default RE: Climate Control ! Sleepwalker? Lugnut?
Your symptoms don't signal a fault.
Once the car is up to temperature the climate control decides the cabin is too hot (the driver and the sun act as a heat source into the cabin) and lets some cooling air in to stabalise the temp at the set temperature.
Moving the setting to Hi calls for more heat so the cool air stops and more heat is delivered.
Stuart
Old Oct 17, 2006 | 12:48 PM
cmackvt's Avatar
Thanks, but the heat doesn't come back on by itself. It will stay off until --well until you restart the car, or turn the heat to hi.
Leo L.
Apr 25, 2006 06:38 PM
C280 wizard
Mar 25, 2006 05:43 PM
fay3131
Mar 11, 2006 02:53 AM
ronsl500
Jul 30, 2005 07:40 PM
Buck
Jul 10, 2005 12:33 AM
