more
Old Oct 17, 2006 | 02:01 AM
cmackvt's Avatar
Default more
Just to add . I just ran a diag. on the climate control and came up with these E codes. 1231(ECT sensor) Whats That?
1234( Sun sensor) Got that one!
1459(Series interface connection to instrument cluster) Huh?
How do these affect the operation of the climate control module?
Are they responsible for the current problems?
Thanks again people! Chas.
Old Oct 17, 2006 | 04:06 AM
snanceki's Avatar
Default RE: more
Just to add?
What problems?
Stuart
Old Oct 17, 2006 | 04:08 AM
snanceki's Avatar
Default RE: more
Incidentally ECT = Engine coolant temperature.
If your instrument pack is reading correctly then this is unl;ikely to be a cause since the same sensor is used and the data is trans via the CAN.
Stuart
Old Oct 17, 2006 | 12:53 PM
cmackvt's Avatar
Default RE: more
Hi Stuart, I had another post right before this one. Its about the heat reaching temperature, then shutting off. Only restart is to either turn off ignition and restart, or turn temp all the way to hi. Other temp settings do nothing. Thanks! Chas.
braadstaan
Apr 3, 2011 12:03 PM
BuyMBparts.com
Sep 8, 2006 01:01 PM
Lugnut
Jan 13, 2005 09:48 AM
OffroadGirl
Nov 16, 2003 08:06 PM
enigmax30
Sep 13, 2003 09:00 PM
