Another Blower Regulator question
My a/c blower will only blow 1/2 speed and that's not enough when it's 19 degrees outside! I've done the searches, read about the regulator issues. I've located one for $160.00. I also read on another site that the regulator could be replaced with one from a W125 (I believe...I couldn't be wrong on the chassis, I know it's an S class model) which costs considerably less. Has anyone done this? Are there any issues tousing the other model?
Thanks in advance for any help!
RE: Another Blower Regulator question
If the regulator numbers are different I believe you will be heading for problems.
It may work but something will be different either electrically or mechanically (mounting etc.)
Best bet is to get part no info and see if it is interchangeable.
Good luck,
Stuart.
Good luck,
Stuart.
I came across this... I hope it will help you...
http://www.mercedesshop.com/shopforu...d.php?t=176788
yngrvp
08-05-2006 10:58 PM
