Advice needed, looking to buy E320 Wagon
Old Aug 28, 2007 | 03:43 PM
TNTRower's Avatar
Default Advice needed, looking to buy E320 Wagon
Hey everyone!
I have always been an admirer of MB engineering and now I am able to actually join the family! To that end I am looking at buying a '98, '99, or 2000 E320 Wagon. I have read great things about the vehicles but something popped up and I had a question. How hard is it to change the plugs on this vehicle? Also I have read about the FSS and am amazed at the intervals. Can you all help me with anything else I should be on the lookout for when I am buying from some independent dealers or owners?
Any help is always appreciated.
Drew
Old Aug 28, 2007 | 05:44 PM
NAZ's Avatar
NAZ
Default RE: Advice needed, looking to buy E320 Wagon
check for corrosion on the door seals push the seal with the finger and check for rust check on four doors thats 1,check the front suspension heights they had alot of trouble on the frount spring cups for corrosion thats 2,when test drive filled the gear changes for smoothness thats on if its auto other than not a bad motor .........spark plugs if its the v6 than there are abit of pain to change ,if its a stright 6 they ok to do............
Old Aug 28, 2007 | 07:37 PM
ohlord's Avatar
Banned
Go to the W210 wiki (google)for lots of info and data, recall on early harmonic balancers so make sure it was done if that model needed it,spring perches on 98-99,spark plugs every 100000 miles and not hard to do youself,diy over on benzworld.org,,shop around,got ours for $9500 it's a 99 white and runs like a top,do your own maint. and they will run for a long time.If you can do your own repairs and maint,I would get it if i were you,if not you better not mind sky high dealer charges and have deep pockets.Look for a low mile 99-00 inspect it,and buy private, the dealers start their screwing long before you have it serviced the first time.Look around on the other forums for w210 model,mbworld.org and benzworld.org.
Nuf info?
ohlord
"GOT CODES?"
and check here or on the other sites before you buy,so we can see if the car and deal make sense.
Old Aug 28, 2007 | 08:04 PM
TNTRower's Avatar
Beauty! I will check those other sites out. Yes I do my own maintenance. I have not graduated to Transmissions but engine work and other stuff that is over the fender is not a problem for me. By the way, what kind of gas do these guys work best on?
Old Aug 28, 2007 | 09:43 PM
ohlord's Avatar
Banned
Ah,the prime mover,the engine of the world. The question is now,where is J.G.?
Premium fuel only in these high compression babies,they will return 22city/28hway,not bad for 0-60 in under 8, in a 3700 lb wagon that seats 7(our two still at home love it).
have fun
change the tranny fluid and filter,they are really not lifetime fluid.
99 you can drain the converter.
look on crazedlist.org and search all the states around you at one time.
ohlord
"GOT CODES?"
methodsman
Mar 3, 2012 01:40 AM
reddevil
Feb 9, 2009 02:00 PM
warpman89
Dec 3, 2008 08:10 AM
RJT
Jun 29, 2008 08:39 PM
joe maniqz
Oct 29, 2006 05:44 PM
