AC temp control
Old Jul 20, 2007 | 10:39 AM
caga10's Avatar
Default AC temp control
"97 E420.... has anyone changed the sensor on their AC.....??? If I leave it at LOW mode...it stays cold..[sm=smiley14.gif]?? but if you adjust to any temp..... it doesn't work..?? it just shuts off and blows outside air[sm=smiley6.gif]...?? let me know...thanks
Old Jul 20, 2007 | 01:49 PM
ohlord's Avatar
Banned
Default RE: AC temp control
Don't know how they changed between 97 and 99 but if you have onboard climate control diagnostics,run them post the values and error codes and maybe someone has the solution.Lexrex over at mbworld.org forum has tons of info on a/c so maybe you should check out those threads.Is it dual climate control?Do you know how to run the tests?
hope this helps a little
ohlord
Old Jul 23, 2007 | 09:54 AM
caga10's Avatar
Thanks...bro... will check on that..
Old Jul 23, 2007 | 11:35 AM
ohlord's Avatar
Banned
run these,
www.eclassbenz.com/node/27
be sure to run the error tests.
post values
ohlord
GotRide
Apr 8, 2008 10:24 PM
roaster
Nov 9, 2006 10:30 AM
miishmiish
Jul 9, 2006 03:13 PM
mambodave
Jul 7, 2006 11:12 AM
WetWillie
Sep 26, 2005 12:37 AM
