AC Leaking
Old Nov 22, 2004 | 08:47 PM
jvision09's Avatar
Default AC Leaking
my AC on my 1994 e320 sedan does not blow cold, the mechanic put feron in it and about 3 days later all of it leaked out, he said it will cost 1200 to fix, im thinking the evaporator is leaking since it does not show a leak anywhere else under the hood, and also only my 2 middle vents blow air out, the ones on the side do not blow air or blow very little. Would i have to remove the dashboard to see the problem, any info would be helpful, thanks.
Old Nov 22, 2004 | 10:07 PM
sleepwalker's Avatar
Default RE: AC Leaking
it is definitely leaking.
you will pull out the evaporator anyway, so check the vacuum system as well. (elements, hoses, valve block, connections).
replace only the evaporator after and extesive check and no external leak is found. some oil spot must be visible on one area of evaporator that confirms the leak. if no oil spot, check further more.
Gary77
Apr 30, 2008 04:06 PM
posmaxx
May 11, 2005 12:18 AM
ESG
Jan 28, 2005 10:24 PM
bumanng
Dec 24, 2004 02:59 AM
jab
Apr 17, 2004 10:22 AM
