'99ml430 beep and blinking
Old Mar 7, 2009 | 09:38 PM
chaisone's Avatar
Default '99ml430 beep and blinking
Hello everyone,
I have a '99 ml430. This evening as I was driving home, I heard a beep. I thought it was my phone, but after checking my phone I reallized it wasn't the phone. I odometer wqas flashing "-2.0L".
Does anyone have any diea what this means? Is it serious? After a glance at the water temp level, I decided it was OK to continue home, which was another 4-5 miles. I drove it home, it is dark, so I'll check oil level and check for any leaks and such tomorow.
Thank you all in advance for any info.
Old Mar 10, 2009 | 09:15 AM
mbenz80's Avatar
Two liters (quarts) short on motor oil level. Check with dipstick to make sure you have enough oil in your engine. If it is OK, your oil level sensor is bad. Regards, Bernard
Old Mar 10, 2009 | 07:08 PM
chassis221's Avatar
oil leaks come from the filler neck, also the valve cover gaskets and also the small square oil pressure access area under the oil filter assembly area. square/rectangle about 1 in by 1.5 inches they leak alot too.
phyberlink
Sep 16, 2012 11:57 AM
ispt17
Jan 5, 2010 10:03 PM
99njml
Feb 26, 2009 07:11 PM
itchy13
Feb 16, 2008 11:33 PM
coryskeet
Jun 25, 2007 06:40 PM
