96 E320 does not crank
Old Jun 11, 2008 | 09:40 PM
bm37's Avatar
Default 96 E320 does not crank
I have owned this E320 since new, and it always performs excellently, but suddenly a few days ago, it refused to crank. The K-40 unit and all the fuses were checked ok. The starter sounded to have engaged but did not crank. What can be done ? Will any one please advise!
Old Jun 11, 2008 | 10:38 PM
cliff's Avatar
Default RE: 96 E320 does not crank
not to ask the obvious, but, dead battery? did you try to jump it? sorry if that's too plebian...just a guess
Old Jun 11, 2008 | 10:47 PM
bm37's Avatar
Tks Cliff,
The battery is new and fully charged, but could not figure out what went wrong.
Old Jun 12, 2008 | 10:15 PM
cliff's Avatar
solenoid could be shot...
Old Jun 13, 2008 | 05:04 AM
frk203's Avatar
i had a problem with starting with my s-class check this forum to see if your problem is the same:
https://mercedesforum.com/m_72057/mpage_1/key_/tm.htm
Old Jun 13, 2008 | 04:05 PM
bm37's Avatar
The solenoid seems to be OK, because I can hear the engagement sound , but only the crank does not happen. I will follow the S-class solution to check it.
I suspect that the starter motor might have poor contact or worn-out brushes. I will try to take out the starter and check it.
Old Jun 20, 2008 | 09:38 AM
418viper's Avatar
Just had this issue on my brand new corvette.Everything worked but car would not crank. Checked the battery and the negative terminal was loose (from factory???) and had subsequently corroded. Cleaned off and re-installed, tightened and coated both terminals with di-electric grease.Everything now ok. Check your cables at the battery.
Old Jun 26, 2008 | 04:58 PM
bm37's Avatar
Latest update: The starter cable was not conducting properly, and not the other possibilities. After changing a new harness, the car is OK.
seensee
Jan 4, 2014 07:22 PM
Jopenko1
Dec 10, 2012 03:18 PM
jspskompressor
Nov 25, 2010 10:49 AM
87MBZTurbo
Aug 30, 2009 06:06 PM
fcasadon
Jul 9, 2005 11:08 PM
