220TE engine noise
Old Jul 29, 2004 | 07:37 AM
timguildford's Avatar
Default 220TE engine noise
Have a '93 220TE and the petrol engine is starting make a noise like a diesel, sometimes at start-up and when idling. Seems to be temperature-related, but not sure. Also getting a 'rattling' noise when accelerating at low speeds. Any suggestions welcomed. Thanks.
Old Jul 29, 2004 | 09:20 PM
sleepwalker's Avatar
Default RE: 220TE engine noise
pinging?
Old Jul 30, 2004 | 05:31 AM
No, it's more the sound of a diesel engine when idling - a 'clattering' noise, sometimes on start-up and then when the car is stationary. The noise under acceleration is difficult to describe: it's a sort of rattle, which disappears when the speed settles down: seems to occur partcularly when accelerating uphill.
Old Jul 30, 2004 | 07:00 AM
it's a knocking noise then?
the noise in the diesel sounds like knocking especially if the fuel delivery is not the same on every cylinder. unburned fuel causes the knock.
in your case it is not a fuel problem but a mechanical problem. it must be the CONNECTING ROD.
during startup and the engine oil is cold, the viscosity is still low and therefore cannot circulate immediately. due to lack of pressure lubrication on the connecting rod bearing, the clearance got play, and have this noise. was this guess of mine make sense? when you shift to drive, the noise changes?
this is the only case that you might possible got in your car. it is not a valve tappet because you know this kind of sound.
make sure the oil pressure is 3bar at 2000rpm.
replace the connecting rod bearing before it start to damage the crankshaft journal. this way, you can save a lot of money and time.
Old Sep 5, 2007 | 07:01 AM
JP E220's Avatar
Hi timguildford,
Have you ever found a solution to the problem mentioned above?
I have the same problem on my E220 sedan under acceleration. The sound seems to be coming from the passenger side, under the glove box somewhere.
ensten
May 9, 2006 09:42 AM
patgrpatgr
Dec 22, 2005 08:36 PM
JC untapped 93 600SL
Aug 23, 2005 07:40 PM
trymonlam
Aug 20, 2005 08:15 PM
CCCP
Feb 18, 2005 05:00 PM
