1999 E320 - stalling when idling
Old Oct 28, 2004 | 10:18 PM
COFIELD's Avatar
Default 1999 E320 - stalling when idling
Car stalls when idling. I attempt to re-start it and it turns and turns but will not start. Generally, about 15 minutes later, it starts right up. Anyone have any ideas on the cause?
Also, the other day, the radiator fan turned on and did not turn off until the battery was completely drained. Got car jump started and problem has not occurred again. Any ideas?
Car has been in shop for a week with no progress on repairing it.
Thank you.
Old Oct 28, 2004 | 11:34 PM
MB/TECHMAN's Avatar
Default RE: 1999 E320 - stalling when idling
COULD BE WIRING HARRNESS TO ENG CHECK TO SEE IF ITS CRACKED UP AT THE CIOL PACKS AND INJECTORS....POSSILBE ..MASS AIR METER,,BEST THING TO DO IS TO GET IT SCANNED ,,IS CHECK ENG. LIGHT ON???
Old Oct 28, 2004 | 11:40 PM
COFIELD's Avatar
Thank you. I will suggest this to the technician. I was driving at a low speed a few days ago and the engine sputtered and nearly stalled, the Check Engine light came on. However, since then it has turned off. However, after this occurred is when the other problem started - the stalling when idling. It only does it occasionally.
kayakbound
May 24, 2014 09:37 PM
ajh_28
Feb 8, 2007 06:39 PM
beamer
May 18, 2006 03:13 PM
shadetree
Sep 27, 2005 05:41 AM
thecapitalizt
Sep 18, 2005 12:22 AM
