Windscreen washer
Old Oct 28, 2012 | 02:12 PM
DavidPilling's Avatar
Default Windscreen washer
Could anyone help, the washer doesn't work on the wind screen and doesn't sound as though the pump is working, is there a fuse I can change.the manual doesn't say where it is
Old Nov 6, 2012 | 01:12 PM
PelicanParts.com's Avatar
Year and model of your CLK?
Old Nov 6, 2012 | 05:47 PM
chassis221's Avatar
[QUOTE=DavidPilling;160341]Could anyone help, the washer doesn't work on the wind screen and doesn't sound as though the pump is working, is there a fuse I can change.the manual doesn't say where it is[/QU
I doubt its a fuse.probably bad pump or a bad turnsignal stalk. but you can check the fuses. should be under the hood fuse box. just look at the fuses with a flash light you can usually see a blown one. when you operate it. you usually can hear some noise from the pump. you can unplug it and check for 12 volts at the plug when you operate the washers.
paulwith
Jan 24, 2009 10:53 AM
zoom480
Nov 12, 2008 10:46 PM
denverbres
Feb 16, 2008 09:15 AM
horseybird
Oct 27, 2007 02:12 PM
stinger
Nov 18, 2005 12:15 PM
