Windscreen washer not working again
Hi
Still having problem with washers on 01 320 slk. I've replaced the jets with genuine parts.I've tried to remove the washer bottle and pump after removing wheel and wheel arch liner.Seems to be just one bolt holding the bottle but having taken that out I can't seem to remove the bottle to access the pump and pipes, (I did remove the clip on one of the visible pipes but it turned out to be a heater hose full of coolant! I think? The pump sounds fine.How do I remove the bottle and pump without removing the wing!?
Woul appreciate any advice,It's driving me nuts!
