Radio wont work
I purchased a used 2005 clk 500 9 months ago today I got in the car and the radio display is on but no sound is coming out of the speakers same with the cd player. I tried turning the radio off and on and turning the volume **** all the way around nothing worked. Only other problem Ive had with stereo is when I play some burned cds they would not play right away but after a minute they will play. Any help appreciated as to how to fix this.
Thanks for the reply I never did do the fuses. The next morning when I started my car the radio was working fine. I did some more searching and found people had similar problems and it turned out to be the amp(had to get a new one). So if it happens again I have a couple of plans. have a good one
I have a 99 clk430 that all of a sudden the radio has no sound. I have checked fuses and unplugged the cd changer and plugged back up with no resolution. I have read the cd changer plug sometimes can be loose and cause no sound. Is there a simple solution to this problem? Will I need to replace the radio itself?
pags
Nov 7, 2007 10:52 PM
