wipers wont work
hello, new person here, my wipers dont work. the car is a 1992 500sl the symptoms are: on position 1 wipers sometimes work, then dont run again after i pull away from some lights. sometimes sweep when i push the stalk, sometimes not. they always work on position 3, and sometimes work on position 2(running then intermittent at a standstill)
apart from that the car is great. thanks again
could be but is the multi function relay more likely given the symptoms. also could it be a bad earth, i've heard of an earth behind the offside headlamp that can give problems like these, and coincidentally the previous owner has tinkered here? any thoughts
gratefully listened to
bright rider
Sep 12, 2008 02:03 PM
