CAR TROUBLE
Old Dec 4, 2003 | 04:01 AM
ONLY20S's Avatar
Default CAR TROUBLE
MY CLK KNOCKS WHEN I FIRST START IT UP FOR THE DAY. THE KNOCK GOES AWAY ONCE THE CAR IS WARMED UP. DOES ANYONE KNOW WHAT THIS PROBLEM IS?
Old Dec 30, 2003 | 11:19 PM
jwnpgh's Avatar
Default CAR TROUBLE
Hi
I have an 03 clk 320 and it also has a knock when cold. I asked the dealer and they said it was normal.
I have tons of electrical problems though. I posted a question wondering if anyone else is.
John
Old Jan 2, 2004 | 01:10 PM
Lugnut's Avatar
Default CAR TROUBLE
It's piston slap. Not a hugely big deal if you don't hotrod it while it's cold. Drive it veryeasy until it's warmed up. A lot of newer cars do this, especially ones with an aluminum block, heads or both.
Old Jan 5, 2004 | 01:13 AM
ONLY20S's Avatar
Default CAR TROUBLE
<FONT face="Arial, Helvetica, sans-serif">THANK YOU FOR THE INFO ON THE KNOCKING. I THINK IM GONNA GET RID OF THIS CAR ANYWAY. NO KNOCKS CAN BE GOOD FOR A CAR.</FONT>
Old Jan 5, 2004 | 04:33 AM
Lugnut's Avatar
Default CAR TROUBLE
Piston slap isreal-world engineering at work. I wouldn't dump a late-model car because of it. Extremely tight tolerances on hotter running modern engines isn't desirable.Think of a better reason to get rid of it. </P>
Old Feb 4, 2004 | 10:11 PM
westscot's Avatar
Default CAR TROUBLE
Good chance you have delay for oil to reach the top of the engine. Mine does it too, but only very slightly and it goes away in about 20 seconds. Noise is very slight. Did you put in a non-OEM filter? Possible cause. Some filters have a valve to prevent oil draining all the way down, but cheap ones usually don't.
Old Feb 5, 2004 | 03:32 AM
ONLY20S's Avatar
Default CAR TROUBLE
THANKS FOR THE INFO ABOUT IT POSSIBLY BEING AN AFTERMARKET OIL FILTER. I HOPE MY CHEAPNESS DIDNT CASUE MAJOR ENGINE PROBLEMS. I HAVE MY OIL CHANGED AT A QUICK LUBE SHOP. I THINK IM GONNA HAVE THE DEALER CHANGE MY OIL NEXT.
Old Feb 5, 2004 | 11:15 AM
westscot's Avatar
Default CAR TROUBLE
Oh, and another thing,</P>
Don't change the oil too often, this is a false economy. Use the correct weight oil and original brand filter and only do it when the wrench lights up on the dash, not before. These engines "add up" all the driving experiences depending on your driving style and report to you when to change it. Doing it early and often, especially with an aftermarket filter, is costly short and long term. Mercedes now recommends synthetic oil in all these engines too, so viscosity is not lost over time like mineral oil blends.</P>
Old Feb 5, 2004 | 02:55 PM
  #9
ONLY20S's Avatar
Default CAR TROUBLE
IM THINKING ABOUT CHANGING THE OIL AT THE DEALERSHIP SOON SO IT HAS THE RIGHT GRADE OF OIL IN IT AND THE ORIGINAL OIL FILTER. THRE KNOCK GOES AWAY AFTER LIKE 3 MINUTES. I HOPE THERES NO REAL DAMAGE TO MY MOTOR. THANKS AGAIN
keredchang
Dec 22, 2010 07:23 AM
angelkattexas
Jul 17, 2007 11:47 AM
THESHAKER
Dec 2, 2006 04:49 PM
kompressorboy8
Mar 17, 2004 03:42 PM
john5
Jan 28, 2004 08:58 PM
