A class cutting out
Old Dec 5, 2006 | 03:02 PM
sjh's Avatar
sjh
Default A class cutting out
I have an A class 1998 1.6 semi automatic (with 38000 on the clock) that used to run great up until about a week ago and then without warning , suddenly started to run like an old dog , spluttering out black smoke and loss of power , until I changed the plugs (which where filthy) , oil and oil filter.
I have also sprayed the MAFS with carb cleaner.
It now runs smoothly enough when driving but it will only run idle for around 30 seconds before cutting out.
It also cuts out when stopped at lights etc.
Any ideas what to check and/or clean next ?
Hopefully you can help me out.
Regards
Scott
Old Dec 23, 2006 | 05:46 PM
jyautoelectrics's Avatar
Default RE: A class cutting out
I have the same problem with a 1998 Manual A140!!
I have already tried the same things as you.. If you get anywhere drop me a email..
Cheers
John
Old Jan 8, 2007 | 01:00 PM
tracy's Avatar
Has your air mass sensor been checked out?
Old Aug 31, 2007 | 08:55 AM
zurgen's Avatar
Hello
i had the same problem with A160 1998 and it was throttle actuator
itcan be fixedeasily
ifyou want i can show you how
Old Aug 31, 2007 | 03:08 PM
NAZ's Avatar
NAZ
you need to check the throttle actuator possible excissive carbon on it ,if you find carbon on it you need to clean it,and test it......if the air mass was faulty check engine light would have come on this models are sensitive....
s.hurley
Mar 5, 2012 02:13 AM
gongie
Jun 22, 2010 04:22 PM
ianellerby
Mar 15, 2006 12:57 PM
ianellerby
Feb 16, 2006 09:42 PM
dlicheri
Sep 30, 2005 08:12 AM
