WINDOW NOT OPENING
Old Mar 19, 2008 | 10:33 AM
Year1998C200's Avatar
Default WINDOW NOT OPENING
HEY,
i have a w202 c200. my rear left window is not opening. i have noticed also the switch for opening the window does not light up when i switch on my headlights at night. could it bea power problem. could it be a fuse and if so which fuses should i check. kindly help out.
Old Mar 19, 2008 | 10:53 AM
mrcoyote's Avatar
Default RE: WINDOW NOT OPENING
The switches are fairly easy to access. Remove the switch from the door panel and get a 12V tester. Check the switch with this with the power on. If you see 12V AT THE SWITCH, the switch is bad and all you have to do is unplug it and plug in a new one. If there is NO POWER AT THE SWITCH, it's further up the wiring to the fuse box or between. Usually, USUALLY, fuses for window switches control them all, so I am suspicious more of the switch itself than what might be an individual fuse for just that window. Very rare to have a fuse in a fuse box for each window. Hope this helps.
Old Mar 19, 2008 | 01:52 PM
hey,
thanks for the reply. but i thought if the switch was the issue, i would still be able to use the switches thats next to the drivers at the gear panel.
Old Mar 19, 2008 | 04:08 PM
mrcoyote's Avatar
Power would still have to flow through the switch on the door, so.......if that switch is faulty, it's unlikely that the switch
you control as the driver would have an effect. Power may be stopping at that door switch. First thing is to start at the
faulty window and trace it from that switch. If there's power to that switch, and
nothing happens when you operate it at the door, jump it with a small wire and see if the window moves. If it doesn't, it's
the motor, not the switch. If it does move, it's the switch.
noelennis
Sep 22, 2007 12:50 AM
speedygonzales
Feb 16, 2007 02:38 PM
bluejay2go
Jun 26, 2006 03:58 AM
mercme110
Mar 31, 2006 08:39 PM
seitz729
Sep 23, 2005 05:44 AM
