Turn Signal Bulb Replacement
Old Sep 17, 2009 | 11:23 AM
ACat299612's Avatar
Default Turn Signal Bulb Replacement
I recently purcahsed as 2001 C240. The left front turn signal bulb burnt. I tried to follow the instructions on replacing the bulb. I "turned" the "socket" as instructed, but when I try to pull the bulb out, the entire headlight assembly seems to move, and I cannot pull out the bulb "easily". I have not tried pulling hard, as I am afraid something is wrong.
Am I missing something.
Old Sep 17, 2009 | 04:18 PM
mrcoyote's Avatar
Talking
No, you're on the right track. Just turn it and pull it straight out. It's probably just a bit
stuck.
Old Sep 21, 2009 | 07:08 AM
rsmceo's Avatar
Exactly. The lens just pops out and then the bulb does the same. Pretty straight forward. I went ahead and changed out both of mine assuming the other would burn out too.
drfil
Nov 8, 2011 09:03 PM
rradlein
Feb 6, 2011 10:22 AM
ACat299612
Sep 26, 2009 10:53 AM
nat54
Jan 23, 2008 04:25 PM
mle095@gmail.com
Jan 22, 2007 12:56 AM
