Sluggish Key Fob
Old Jan 26, 2007 | 02:17 PM
C240RedGirl's Avatar
Default Sluggish Key Fob
The key fob for my 2001 C240 is sluggish and will only work at a close distance. Is there a battery to change? If so, how do I get at it?
BTW, I'm told there is no Hanes or Chilton manusl for this car. Where can I get a comparable manual?
Old Jan 26, 2007 | 02:32 PM
mbz300sdl's Avatar
Default RE: Sluggish Key Fob
Yeah its the battery but i dunno how to change it my MB doesnt have a key like urs.
There is alway buying a factory manual from the dealer $$$ some of those Ebay CDs are good and some arent id stay away from those.
Old Jan 26, 2007 | 10:36 PM
Shan's Avatar
Move the little plastic slider at the top of the key away from the metal key and pull out the key.
You will see a greyish plastic thing in the groove from where the metal key came out.
Use the tip of the metal key to gently push the clip forward and while holding it there pull out the top
section of the plastic key holder.
The battery holder will slide out.
Change the 2 batteries (CR2025). You should be able to buy them from any outlet that sells watch
batteries. Make sure you follow the polarity of the batteries crrectly when fixing.
Fix it back into thekey holder and you are done.
SHAN.
rjungling
May 25, 2021 08:48 AM
C240RedGirl
Jan 26, 2007 02:14 PM
mercedesml320VA
Jan 10, 2007 12:49 AM
sureshbabu97
Jan 2, 2006 02:53 PM
emotechnik
Nov 7, 2004 09:38 AM
