Question for Sleepwaker / steering noise
Old May 11, 2008 | 06:11 AM
platonmind's Avatar
Default Question for Sleepwaker / steering noise
I have `98 C230 and I can`t figure out where low screeching sound is coming from every time I turn the steering wheel to the LEFT. Power steering fluid is OK and there is no leak. By the way, is there any greese fittings points on the car? Thank you.
Old May 11, 2008 | 04:09 PM
C280 SPORT's Avatar
Default RE: Question for Sleepwaker / steering noise
Oh my god same here. I have a 2000 C280 that does the same thing. Let me guess it does not do it when its cold thou? I got my sterring fluid changed thinking it would help but nothing at all. As long as its cold out it makes a funny sound. There are a few people with W202 That have ha the same problem.
Old May 15, 2008 | 02:20 PM
Enginerd's Avatar
I'm no pro guys, but my past experience with other cars leads me to believe a loose or slipping belt. Usually the steering is harder than normal.
If not that I'd say your P/S pump is on the fritz.... somtimes dirt gets in there and makes a mess.
Old May 15, 2008 | 09:09 PM
sleepwalker's Avatar
that depends on where the noise is coming from. it's either steering gear, steering pump or steering column.
if the car experienced a minor accident on the front or hard bumps that bent any tierod or suspension parts, it will affect the steering also.
best way is to pinpoint first the exact location of the noise. then we start from there.
Old May 16, 2008 | 06:50 AM
platonmind's Avatar
Low noise is coming from the upper part of the right wheel. Car never been in accident.
SRLassit
Jan 31, 2008 03:01 AM
AMGMercedes
Apr 2, 2007 10:49 PM
craig green
Mar 17, 2007 08:35 PM
klebbaj
May 15, 2005 10:43 AM
Taddub
Jun 10, 2004 10:55 AM
