Mercedes repair secrets
All secrets of how to repair your Mercedes car as easy as 1 , 2 , 3 .
Problems in Keys
Problems in ECU
Problems in O2
Variant Coding
Airbag modifications
ATA ( Anti - Theft Alarm System )
All Star Diagnosis faultcodes repair+ Programming
All you need is just send me the problem that your car is facing , and i will send you the repair instructions.
Problems in Keys
Problems in ECU
Problems in O2
Variant Coding
Problems in Keys
Problems in ECU
Problems in O2
Variant Coding
Problems in Keys
Problems in ECU
Problems in O2
Variant Coding
Drove up to Oakland from SoCal when i arrived fan or something was making a pretty good clicking noise sounded like it was running light on coolent or something?? anyone know anything???
Have a 2000 C230K set code po410 cleared with generic code reader , drove few days and it came back. I have found ever so slight amounts of rust in the check valve 0021402860 (number on Valve)
Question : Is there a reliable source for the valve in the aftermarket? am I even on the
right track?
right track?
My C230k 2004 sedan have a diagnostic report fault codes P0452 and P0172. A mechanic told me that had problems with the pressure sensor low input and need to replace the fuel pump assembly. I was searching the web and I find that this model has two fuel pumps one in the passenger side and other on the driver's side. Which of the two is the report? Anyone know what the replacement number for this part? And install it.
benchmark88@gmail.com
Hi, i've got a 230K - S Reg, and have been having the following problems:
At first, when starting the car (normally first thing in the morning) it would start but completely lose all power and be jumpy (as if it had run out of petrol) it would barely drive and felt like it would cut out, this would normally last five minutes and then the car would run fine for the rest day.
It has now been left unused for the past month or so, now it turns over and fires but will not run. We have changed plugs but still same, please help.
Hi there
I hope that you can help me. I was driving my car today and it just died, while waiting for AAA to arrive after 20 minutes of waiting it turned over fine, until then it would turn over but just not start as if it were out of petrol. Lights, radio everything worked fine and clearly not a battery issue. When I finally got it started I drove home ( approximately 8 miles ) and there were no obvious signs of trouble except the check engine light.
Can you tell me how I can get to find the diagnostic error code? Also any ideas on what might have caused it?
Earlier in the day while sitting at a light it stalled for no apparent reason but restarted immediately with no problems.
Many thanks in advance for your help.
Paaschie
Paaschie
i own a 2001 C240. the control arm bushings need to be changed and i thought you could help me with a detailed process and some photos.
it would really help me to save probably a thousand $.
my e-mail is roaldi.joco@yahoo.com
thank you very much
my e-mail is roaldi.joco@yahoo.comthank you very much
After buying ATF from my local MB Dealer I parked my car on my dryway to service myself the transmission. To be able to remove the ATF from the converter and get access to the plug I move the engine crankshaft with a rachet until the converter plug was visible, perfect job and the tranny was service. Now the car do not start.
Ok. The engine crank but dont start, after looking and looking the crankshaft sensor was dirty, after a good clean job the engine start, after turn the engine off and try to start again the engine was dead, again crank and nothing. Back to the dealer I install a new sensor with his original spacer washer and the same problem, but this time, when the sensor its pull up aprox. 2mm from his original position the engine start and works perfect but the engine do not acelerate, hesitate like needs gas, obiously the signal from the sensor its not syncronized (I think).
I try to give you the hole picture of the problem, at this point I dont know what its wrong so please any tip or idea of the solution will be appresiate.
Thanxs
mbenz66
Thanxs
mbenz66
Hello Star_Expert, hope you can help me with my problem.
I have a problem with my rear wiper: it works fine but the water squirt no longer does. I've had the pump tested and it's fine and as the wiper works, I'm guessing the link between the switch and the pump is OK so that just leaves the switch itself.
What do you think the problem might be and how do I fix it?
TIA
TIA
