Mercedes repair secrets
Old 06-09-2009, 05:02 AM
shokwaves's Avatar
Default Power Seat Headache
Hey Now...
Car is a 2002 C320 wagon. The driver's side power seat fore/aft function does not work. When the memory feature is pressed, the seat moves fore/aft, so the motor is fine. All other functions work fine.
Any suggestions? Can this be resynched?
Thanks!
  #142
Old 06-09-2009, 04:51 PM
adword's Avatar
HI,
i have a mercedes A170 diesel automatic.It was idle and not running for 2 months in cold weather.And now it does not start at all .Could you please advise.
many thanks
Adword
  #143
Old 06-10-2009, 08:57 AM
Albo4Life's Avatar
I also have the same problem as Marley. I have a problem with my BAS and ESP. Everytime I drive it will at some point come on. Its not caused by harsh breaking etc. What could it be? When I restart the car it dissapears and the returns again at some point.
I have a 2001 C320 and only 46 000 miles!
  #144
Old 06-11-2009, 07:31 PM
lintlars's Avatar
Default 2001 c240 electrical issues
Hi I have a 2001 c240 I have a few electrical issues
1-all my drivers door controls do not work and the keyless entry works for all the doors but the drivers door.I have 12v and ground at the control module inside the door.
2- no controls work on my steering wheel work not even the horn.
3-SRS light is on.
Ive done some searching but could not find anything for the these issues Ive checked all the connections under the seats there is no bare wires where it passes through the door loom.
Thanks any help would be appreciated
  #145
Old 06-11-2009, 08:23 PM
Jim Cahoe's Avatar
Default !997 c280-Windshield wiper switch
I need to replace the windshield wiper/turn signal switch. You have to play with the switch to get the wiper to work. I understand you have to remove the air bag. This concerns me.
  #146
Old 06-14-2009, 10:19 AM
gavinbw's Avatar
Originally Posted by zigyrat1
Hi, I just recently replaced the Altenator and Battery on my 2002 C240 (after dying on me) I was able to reset everything like the ESP, Time, Sunroof.. ect. But I cannot get rid of the SRS alert, A friend told me there may be a specific battery for the SRS system and it may have died with the ALT and Battery, is this possible and if so where would it be and how would I change it. If this is not the case what else could it be? Any help would be much apreciated!
Thanks,
Mike at,
zigyrat@aol.com
Hi Mike, Having the same problem with my 2003 C320 (SRS warning comes on, even after mechanic clears the code). We're also having our engine cooling fan fuse blow regularly, usually associated with either the "display malfunction" warning light, or strangely-performing A/C. Would appreciate sharing updates on getting our issues resolved, since we have the SRS warning in common...
Thanks,
Gavin
  #147
Old 06-14-2009, 02:51 PM
clubleya's Avatar
Default SRS reset
Is there anyway to reset the srs warning light without going to the dealer?
Can you use a code reader?
  #148
Old 06-14-2009, 04:54 PM
stuart2106's Avatar
C220 CDI W202 Year 2000
Hello,
Two weeks ago I came back from holiday and pressure washed my car. The next morning I lowered my electric windows slightly on the way to work. At work my passenger window would not close. (no response from the switch) my Central locking would not work either.
I checked all the fuses and relays in the engine compartment and the box in the boot...All Okay
Three days later, my drivers window would not lower. I have had a suggestion from a very experienced person on another forum that I could have got water into the door controller ECU's, but I have had the passenger door panel off this weekend and they are bone dry. Furthermore, they do not look to be in a place where there could be an ingress of water..
Can you help?
  #149
Old 06-23-2009, 09:50 PM
brendastjohns's Avatar
I need help after changing the battery. The car won't start!
It's a 1998 ML 320 - e mail me brenda@prismnet.com
THANKS!!
  #150
Old 06-26-2009, 10:49 PM
nineintrade's Avatar
hello friends i have c230 1998 all off asudden my car key stopped working i replaced the batteries but still it is not working.pl help me
Quick Reply: Mercedes repair secrets
