mercedes c320
Old Mar 22, 2007 | 06:49 PM
tyman1974's Avatar
Default mercedes c320
I recently had my oil changed and transmission done. When I drove the car, black smoking starting shooting out of the tail pipe. Then when I did an oil change, the oil was black, any help would be great. thanks.
Old Mar 24, 2007 | 08:38 AM
PBI 2001 C320's Avatar
Default RE: mercedes c320 Smoke/Oil
OK. First dont drive it any more- until you have read this. Are you running a Petrol (gasoline) or Diesel?
I have a c320 (Petrol), you should only use someting like MOBIL 1 for either Gas or Derv, its the best and what Mercedes suggest for all there engines.
You will need 2 packs, and yes - thats a full 8 Litres - I think thats just over 2 US Gallons.
The filter must be changed and fill to 7.5 Litres run the engine for 10 minutes on idle - level ground and then use the steering wheel controls to check the oil level.
From the mile reading, engine off, but ingition on, click through engine temp, outdoor temp, service miles etc etc until you get to oil level check, the engine should have been off for about 10 minutes prior to checking, and remember - ignition on, engine off.
TRUTHFULLY!! I thing the smoke must have been caused by overfilling and using the wrong spec of oil, if you dont do this you will cause some very severe engine damage.
Best of luck.
Peter
NOTE 1 x US Gallon is 3.78 Litres, so x 2 will be 7.5 Litres aprx.... Hope this helps
Old Mar 25, 2007 | 12:38 AM
tyman1974's Avatar
I'm using gasoline. Sound like the valve is knocking, can't figure out what it is. I only put 6 quarts of oil, i try puting 2 more and see what happen. and let it run. I trying to reset my service B, read to all the forum and still can't get to reset to 10k.
Old Mar 26, 2007 | 02:58 AM
Shan's Avatar
I believe yours is a W203.
With igniyion on, but engine not running, use the controls on the steering to get the window
that shows a spanner.
Press the reset button on the left side of the instrument panel for a few second ( 2 to 3 sec).
The question DO YOU WANT TO RESET .................. will appear on the screen.
Press the reset button again for a few seconds. The new service interval will appear on the screen.
You are done.
Shan.
Old Mar 26, 2007 | 06:04 PM
tyman1974's Avatar
I believe my piston or valve is knocking on my c320. How expensive will that be?
ashtonroche
Oct 18, 2006 02:41 AM
the mb guy
Oct 15, 2006 02:38 PM
allenlee
Jun 1, 2006 01:16 AM
allenlee
Jun 1, 2006 01:13 AM
cooldude
May 5, 2006 03:00 AM
