Mercedes C220 Issues :)
Old Nov 5, 2004 | 06:47 AM
Benfun7's Avatar
Default Mercedes C220 Issues :)
I have a 1995 C220. The temp gauge dose not work. The only way it comes on is when I am at the car wash and I spray along the crack on the drivers side of the hood. Then it works fine till the car is dry. I checked all the fuses they are fine.
Also is this normal... When you take off, if you floor it it is a bit slugish, but if you put the pedal about 3/4 down it takes off a lot faster.
Thanks,
Ben!
Old Nov 5, 2004 | 09:13 AM
sleepwalker's Avatar
Default RE: Mercedes C220 Issues :)
that depends on which crack you spray.
you got the lead already to find out why... was it because of the water or the lower temp...?
sluggish is not normal. a clogged up exhaust pipe or catalyst can cause it also among other things.
Old Nov 5, 2004 | 06:13 PM
Benfun7's Avatar
I spray it along the crack where the food meets the fender. Right in fromt of the windshield. Could there be a bad ground there?
Thanks so much!
Ben
Old Nov 5, 2004 | 08:38 PM
i haven't encounter such case before.
best way is to find it out.
Scott Mcmillen
Jul 24, 2014 03:50 AM
fivepointohman
Oct 12, 2008 11:00 PM
poitin
Nov 7, 2007 10:42 PM
Drskipper
Jul 22, 2007 07:14 PM
VIPERBLUELX
Mar 7, 2007 02:02 PM
