malfunction after battery change
Old Mar 9, 2007 | 08:10 AM
sg1's Avatar
sg1
Default malfunction after battery change
hi guys this may be very simple but im not sure - iv just changed the battery on my sisters c180 and there is a message on the dash saying [ elec stabil not available ] 1 malfunction . does anybody have any clues any help or advice would be great many thanks [ sg1 ]
Old Mar 9, 2007 | 12:27 PM
Mercedes Benz of FL's Avatar
Default RE: malfunction after battery change
Use OBD Reader to read the Malfunction code
and OBD Reader will also be able to CLEAR the
Malfunction code;
Of course; you want to clear up the malfunctioning
situation
Try this;
remove BOTH battery terminals from Battery
Turn Ignition on
Of course nothing will register as there is no power
Turn Key ON
Leave to Crank On/ON position for 60 seconds to
PURGE capacitors and resistors
Your MB memory will be WIPED OUT
Reset all your necessarys; including clock, alarm code,
etc etc.
Now BEFORE you do this; ASK your local MB Tech.
On American/Jap cars I have done this and successfully cleared the Mal codes, no problem.
MB's-sheesh; its always something eh?
OR USE THE OBDII Reader/Scan
Old Mar 9, 2007 | 03:57 PM
mbgt's Avatar
on my c230 it happens all the time when a remove the battery just drive 10 miles and it will come off
chopper9468
Jul 17, 2012 07:33 AM
Britgit
Mar 21, 2009 08:41 AM
krl
Apr 7, 2007 09:25 PM
james320mb
Jan 1, 2007 11:03 PM
