Help! Transmission problem.
My car is w203 yr.2002 c180. I have problem with the transmission.
The engine light on the dashboard lights up and the transmisssion just wouldn't shift to higher gear, using only single gear.
Have tried to do everything with the gear shift (changing mode to w, s, using tiptronic, etc..). But the car just didn't respond.
The engine warning indicator lights up right after the car try to change gear (with very harsh jerking movement).
Now it's on permanently. What seems to go wrong?
RE: Help! Transmission problem.
I'd agree that you should visit the dealer but you might find that it isnt anything major. On my car it was the brake light switch on the brake pedal that was causing the problem and they replaced it for me free of charge.
Leo
Leo
Just to update on thing,
apparently the problem was caused by flat battery, or so I was told by a merc technician.
all they did was reset the sensors, and everything work fine (and hopefully will stay that way from now on).
2000MBml430
12-30-2008 07:52 PM
