Need help, S320 and ML320 transmission problem!!!
hi to all
Could some body help me give my the right way to fix the S320 and ML320 transmission both have the same problem when I using MB STAR 2000 scan for the fault code it appear ( 050 Gear comparision negative not achieved, and one more code is, 151 Sporadically Gear coparision negative. Target Gear not achieved.) when I disassemble everything inside is ok and when i install it to the car I have check the fluid is ok and try to clear fault code but it still appear old code, does it was from mechanic or ETC problem?
sincerely
sincerely
islandercreation
Dec 16, 2007 02:21 PM
