Help needed C200
Old Jul 30, 2017 | 08:23 AM
farmer680's Avatar
Default Help needed C200
Hi i have a Mercedes C200 1996 model, when i brought it the man said he thinks it has a blown head gasket, i drove it home the temp went to high then dropped back to half, and stayed there,the next day when i started it, it run a bit rough at start up then idled good, there is no milky oil, no bubbles in coolant reservoir, no steam out exhaust but it does leak coolant out of over flow pipe, when running,and there is no heater, was told could be thermostat, any help Appreciated.
Old Jul 31, 2017 | 02:17 PM
PelicanParts.com's Avatar
Hello and welcome to the forum! Before you spend money on parts, get the codes read off the DTC; it'll give you a great place to start troubleshooting. Please let us know if you have any other questions!
Old Jul 31, 2017 | 06:21 PM
farmer680's Avatar
Hi i pulled thermostat out and put it in boiling hot water i couldn't see it open at all like it was seized closed
classik
Mar 12, 2017 10:41 AM
nikdeca
Mar 18, 2011 04:34 AM
Year1998C200
Jul 15, 2007 04:34 AM
bajanboost
May 28, 2007 12:36 AM
