fuel filter change problem
Old Feb 17, 2008 | 11:27 PM
SamChan's Avatar
Default fuel filter change problem
I've change my fuel filter at 60k on my C240. After installing the new filter, when I start the car, ther are gas coming out the fuel filter on the side pointing inside of the car. (It's leaking at 3 and 4)[/align][/align]
Would it be a split/cut on the tube while i cut the OEM hose clamp? My thoughts was if that is the case, can I cut/shorten the tube?
Would it be a bad fuel filter?
Thanks.[/align]
Old Feb 18, 2008 | 08:59 AM
mrcoyote's Avatar
Default RE: fuel filter change problem
Sam>I doubt it's a bad fuel filter. I've never seen one with a split or a crack in it brand new. You may have cut the hose when you took off the original clamps. Or if you really cranked down the new clamps, that can hurt the hose as well.
parasuco
Mar 13, 2009 02:21 PM
djnevoc
Jan 5, 2009 11:37 PM
gazbrasher
Mar 2, 2008 03:42 AM
Corvidae
Apr 20, 2006 07:20 PM
inssane3gt
Jul 21, 2005 04:55 AM
