Esp light intermittent
Old Jan 16, 2022 | 02:17 PM
Dannyc220's Avatar
Default Esp light intermittent
Only when very cold in the esp,tyre monitor light stays on when started,also while the esp on the front washers and wipers don’t work,have to remove the key a couple of times then it will ok till the next day, diagnostic brings up brake light switch ,have replaced it twice with no improvement please help
Old Jan 20, 2022 | 06:42 AM
Joby613's Avatar
Default Tpms light on when cold?
What is your recommended tire pressure vs actual? I've seen low tire pressure set the light on, but it goes off after the car is driven a bit and the tires warm.
I don't know if this would set off esp warnings, but it's as good as any place to start.
edit: if the wipers and washers don't work when the esp is lit the issue may lie deeper.
Old Jan 20, 2022 | 07:04 AM
Dannyc220's Avatar
Default Esp fault
Tyre pressures are all ok,have set them to the recommended setting from the cars data sticker
Old Jan 20, 2022 | 08:05 AM
Joby613's Avatar
The next thing I'd check is the wheel speed sensors. Do you have a scan tool that can access abs data? Also, check your battery/charging system. Corroded terminals and low batt voltage can cause intermittent electrical issues in any of the modules.
Old Jan 20, 2022 | 08:54 AM
Dannyc220's Avatar
Hi,new battery,charging fine,wheel speed sensors ok,can access them through the diagnostic tool,car driving me mad,every day have to turn the wipers on so if they work I know the esp light will go off 😠
Old Jan 20, 2022 | 09:46 PM
Joby613's Avatar
When you check the wheel speed sensors, what tool do you use? Do you check them when you are having the fault? Frankly, I have no idea.
Old Jan 21, 2022 | 12:09 AM
Dannyc220's Avatar
Have a snap on diagnostic and I checked the speed sensors with the esp light on and when it eventually went off,the same readings on all four sensors.
Old May 16, 2022 | 07:49 AM
JohnBeaty's Avatar
I am glad I found your post because I was looking for it for my friend. I was searching for the reviews online for this https://writinguniverse.com/free-ess...s/mesopotamia/ website where I can read essay samples for free. And while reading reviews online, I found your post.
nbrock_85
Apr 1, 2010 06:53 AM
kkourafas
Oct 11, 2008 11:42 PM
thealicat28
Sep 24, 2008 04:39 PM
aharley1
May 28, 2008 06:36 AM
drblank
Oct 12, 2007 07:19 PM
