Check Engine Lamp - P0020 code - cam magnet circuit
I have been getting a P0020 code (with engine light on). I am trying to get an understanding of what is going on here. Everywhere I read that a P0020 is because of an open circuit in the exhaust cam actuator (magnet) circuit. Here is the sequence of events.
But I have some questions about the "stretched chain theory".Are the camshaft actuators (magnets) also camshaft position sensors?
If yes, how can this be since the magnets/actuators are only two-wire. A magnetic, hall or optical position sensor nearly always has 3 wires. 5V+ve, 5V-ve & the sensor output.
If it is in fact NOT the position sensor, where is the cam position sensor on a M271?I will be more than happy to be proven wrong in my assumptions. I just need to get to the bottom of this issue.
- Removed both magnets, Drilled out rivets, and resealed them. Refitted.
- P0020 appeared soon after (one day) - exhaust cam actuator circuit open circuit.
- Removed both magnets. Checked for open circuit and resistance. OK.
- Refitted magnets - swapped inlet for exhaust.
- Still getting P0020 - exhaust cam.
Al Pacino
Mercedes A Class
Sep 15, 2023 09:41 PM
