cam and crankshaft position sensor
Old Aug 5, 2012 | 01:35 PM
pmckone's Avatar
Default cam and crankshaft position sensor
2 times my 05 C240 failed to start after having been drive a while. After waiting 15-20 minutes it started. Took it to my mechanicand he found code of P0341=camsensor performance. He perlaced sensor worked ok twice but then failed. Same code in memory. Further research showed that same code appears for cam and crank sensors and there is no way to tell which. Mecedes says if you chane one you should change the other also. Any thoughts
mcfly
Jun 30, 2011 12:43 PM
zoober
Mar 8, 2008 12:32 PM
BenzoDJ
Mar 30, 2007 08:01 PM
CCCP
Feb 25, 2005 10:41 AM
sdanville
Sep 20, 2004 04:30 AM
