car sounds like bad mattress
C-class are known for there bad lower control arm bushings. The bushings tear and begin to make squeeking noises and even clunking noises. This type of repair will be covered under warranty. If you no longer have warranty than its about a 3 1/2 hr labor job plus
the cost of an alighnment.
Thanks, my car is going in for service next week I'll have the rear shock check. Here is another clue. I hit a raised cross walk, hard to explain what they are, ther higher then the street covered with brick and have reflectors so a driver knows he is approaching it, yestersay, about 25mph and the car bottomed out. I sounded as the bottoming came from the passenger side, I could, tell front or rear? Any suggestions, or do you still think it is the shocks? If they are bad, I think I wll go with a good aftermarket shock? What do you suggest?
bakerboy90660
Sep 9, 2009 11:20 AM
