C280 auto gear change
not always oil and filter would cure the problem.most ofthe time its theactuator stick actuator which damages theCLUTCH K1,WHEN CLUTCH K1 IS DAMAGED IT STARTS TO LOSE OIL PRESSURE AND THE SIMTERMS YOU LL GET IS A THUMB WHEN OPREATING THE GEAR LEVER.by all means check the gear box oil colour by draining it,remove samp pan on the gear box,remove oil filter check for metal filings in the samp.letme hw u get on ................
