w202 auto box will not change gear
Old May 12, 2006 | 05:40 PM
deprince's Avatar
Default w202 auto box will not change gear
C200 w202 the auto box started to change at the wrong time, no kickdown or down changes and eventually went into "safe Mode" i.e can only get one forward gear and reverse.
Any ideas what the problem might be please?
Old May 16, 2006 | 04:43 AM
jnolte's Avatar
Default RE: w202 auto box will not change gear
new tranny, yikes
Old May 16, 2006 | 06:07 AM
sleepwalker's Avatar
read and delete faults.
it can be rpm sensor, or defective solenoid valve.
Old May 16, 2006 | 11:13 AM
vytamenc's Avatar
you need to check the fault codes in in the trans could be n2n3 speed sensors or an etc control unit or a trans however you need to read the codes and look at the adaptations of the trans
Old Jul 26, 2006 | 06:34 AM
deprince's Avatar
Thank you, it was the speed sensor, had to have a new circuit board fitted to transmission. Job was done wityhin a day by a local independant merc specialist
Old Jul 26, 2006 | 12:10 PM
vytamenc and i got it right.
glad it's fixed now. that sensor got a hairline crack on it because of heat.
crishna
Jan 3, 2014 03:54 PM
andyt
Jun 29, 2010 02:29 PM
Vic Clarke
Mercedes A Class
Oct 23, 2009 04:12 AM
marknexus
Oct 4, 2009 11:31 AM
pato_3plus
Jun 29, 2006 02:28 AM
