A/C Questions
Old Feb 19, 2008 | 03:24 PM
C280 SPORT's Avatar
Default A/C Questions
My 2000 C280 Sport has the electric climate control and when the ac or the heat is on I hear like a thumping sound comming from the center and right vents. Is this normal? or a serious problem. When it is on full blast heat or ac the thumping stops but when it is low I hear it. Also when you turn the car off should you turn off the ac or can you leave it on?
Old Feb 19, 2008 | 03:46 PM
lawrencehare's Avatar
Default RE: A/C Questions
It might be something flapping in the ducting, if you close the vents does it go away? If it does not then I would suspect the fan. In the one car I stripped down for some ducting problems it had a centrifugal fan and these can move laterally on their bearings - might explain what you are hearing. At high rpm it settles down and no longer bounces. Would not say it is serious but it might be a sign that the fan is worn...
Which I suppose is serious from the fan's perspective - and it was a heck of a lot of fiddly work pulling it down to get at them ducts - so it may be from your perspective too!
And I never turn the A/C off! It is just a pump after all and it only pumps when it is told to - which will never occur when the engine is off.
My 2 cents worth...
Lawrence
Old Feb 19, 2008 | 03:50 PM
C280 SPORT's Avatar
Thank you for the reply. No it does not stop when I close the vents it still keeps making that thumping sound.
rasputin89
Sep 20, 2004 02:09 AM
olynn
Aug 25, 2004 02:55 PM
youngmercedes
Jul 21, 2004 04:41 PM
cfkingfish
May 1, 2004 11:36 PM
