Air Cond/Fan Squeak
Air Cond/Fan Squeak
I just developed an annoying faint squeak when running either the fan or air conditioner. It is less noticeable at higher RPM's. I'm figuring it is probably a belt or a bearing issue. Anyone have any similar experience? Any help to point me in the right direction would be greatly appreciated. Thanks Dave '01 C240
RE: Air Cond/Fan Squeak
If it's coming from under the hood, it sounds like you might want to take a look at the belt and/or the tensioner. Check to see if there are any cracks in the belt, and also if there is glazing on the belt, it probably needs to be replaced.
Franktime
07-08-2009 12:58 AM
