230 kompressor
Old May 19, 2019 | 04:35 AM
Ihkllass's Avatar
Default 230 kompressor
Start but does not accelerate What is the fault?
Last edited by Ihkllass; May 19, 2019 at 04:43 AM. Reason: Stay idle, if you press the gas the engine shut down
Old May 20, 2019 | 06:13 PM
PelicanParts.com's Avatar
Hello and welcome to the forum. Pull the car's error codes, this will give you a good idea as to where the issue is coming from.
Old May 20, 2019 | 08:59 PM
Ihkllass's Avatar
Hello
The code point to air flow sensor, I bought a new sensor. The fault still persist. I hope to find a solution.
Old May 21, 2019 | 06:53 PM
Originally Posted by Ihkllass
Hello
Did you reset the code after installing the new air flow sensor?
Old May 22, 2019 | 04:59 PM
Ihkllass's Avatar
Default c230 kompressor
c230 kompressor
No I didn't reset the code, I will reset the code. I hope it will solve the problem.
Old Aug 23, 2019 | 01:15 PM
BSKPLoft100's Avatar
how do you reset codes and dash lights, had a ABS !A! come up on a small reader, had the lead and the rotor out and cleaned. Reader now not picking up, but ABS light still stops me getting a MOT
Any body have a good Merc mobile electrician in the Essex area to do a diagnostic, cannot drive car on roads, no MOT
Brian
Old Aug 23, 2019 | 03:05 PM
Ihkllass's Avatar
gear stuck in park, I push a stick through the hole to drive but gear doesn't change remain one drive. please help me solve the issue.
Ryan Davies
Jul 5, 2018 12:48 PM
Mario123
Jun 4, 2018 02:52 PM
hellgrace5
Mar 18, 2010 08:55 AM
Compressor
Feb 24, 2009 04:38 PM
rameets
Jun 19, 2007 09:45 AM
