SLK 230 Kompressor (170) Yr2000 hesitation
Old Feb 21, 2009 | 03:46 PM
Compressor's Avatar
Smile SLK 230 Kompressor (170) Yr2000 hesitation
Hi all
This is my first post (which obviously means my car has a fault)
Intermitant hesitation whether hot or cold - most noticeable after being driven hard (UK car)
Connected it to two OBD code readers - both list misfires from all cylinders -
The car has been regularly seviced and had a few parts replaced-
The Bosch FSA 560 code reader tech info suggested MAF faulty -
replaced with new Bosch unit - fault still present (breathers, intake and oil separator cleaned also)
Plugs were changed twice recently using dealer parts - no change
Coils replaced in desperation - fault still present
Visually leads look ok though they are the next cheapest option to replace
Thanks in advance
Old Feb 24, 2009 | 04:38 PM
Compressor's Avatar
Smile Reply to myself
Fixed it myself - though thanks for reading
After changing Air Mass Sensor I only cleaned as far as the top of the throttle butterfly/valve
However removed Throttle body today and cleaned with electrical cleaning spray
Fixed
Horse
Mar 13, 2008 12:09 PM
brookings
Feb 29, 2008 02:19 AM
ROADRAGE
Dec 31, 2005 03:13 AM
LickVagina
Jun 21, 2005 01:11 AM
the prince
Apr 16, 2005 12:40 PM
