04 c320, trouble with exterior lights
Old Feb 27, 2009 | 11:23 AM
Brygun's Avatar
Default 04 c320, trouble with exterior lights
The only drivers side turn signal working is on mirror, the only brake light that works is the left rear, no rear clearance lights. All bulbs are fine, no power going to bulb circuit boards. What are the chances of both the front and rear Sam modules being bad? If I was to replace these myself is there any need for programming by dealer? Thanx to anyone who can help.
Old Feb 27, 2009 | 03:07 PM
csapi's Avatar
u need just the rear sam. but it must be programmed after u replaced it otherwise won't work. probably not even ur fuel gauge etc.
Old Feb 27, 2009 | 03:09 PM
csapi's Avatar
u can check ur fuses on the left side of ur dashboard.
Old Mar 19, 2009 | 09:13 AM
Brygun's Avatar
Default It's fixed!
I replaced rear sam, fixed only the rear lights. Had to replace front sam also. All lights are working! Did not have to reprogram anything. This job is not rocket science but it took a while to do. Thanks for the responses.
Laura
Dec 21, 2011 08:55 AM
s5barnes
Oct 20, 2011 12:21 PM
levejersey
Jan 24, 2009 11:48 PM
ramdoggg26
Aug 30, 2007 08:11 AM
slick1
Jul 30, 2007 07:05 PM
