Mercedes Benz Forum Help & Suggestion Center Have a suggestion to better Mercedes Forum? Need help with a feature on Mercedes Forum? Post here.
No crank 2003 C240 v6 sedan
Old Jan 6, 2019 | 01:40 PM
Big Nappy's Avatar
Default No crank 2003 C240 v6 sedan
Hi everyone. I have a problem starting my car. 2003 C240 v6 base sedan. First off I all happened about a month ago. The engine wouldn't start however it was turning over just not starting. Now it won't turn over at all. I checked all of the fuses,good. I tested all of the relays,good. Changed the starter relay on a hunch, nothing. Pulled the alternator and battery and had tested at auto parts store,good. Changed the crankshaft position sensor,nothing. I noticed when I charged the battery it read 11.98v and when I installed it after one crank I tested it again and it read 6.20v. Bought and installed a new battery, nothing. Changed the oil, nothing. Bought a new key from Mercedes, still nothing. Looks like the trunk has been leaking water around the fuse panel area as well as a little bit under the hood. It sounds like I can hear the starter click once but now it doesn't click at all. My tranny went out on my truck now both of the vehicles we own are immobile.
Last edited by Big Nappy; Jan 6, 2019 at 01:54 PM. Reason: Forgot to add a description
Old Jan 7, 2019 | 02:48 PM
PelicanParts.com's Avatar
Hello and welcome to the forum! Have you tried pulling the car's fault codes. Even if you didn't get a CEL, there are likely stored codes that should give you a good idea as to where the issue(s) are coming from.
Basil Brown
Feb 5, 2019 07:22 PM
Morvic
Mar 8, 2016 02:49 PM
c230ny
Jun 19, 2015 08:55 AM
Michael Tutt
Jul 20, 2013 06:32 PM
mbct
May 23, 2006 09:20 PM
