Big Nappy |
01-06-2019 01:40 PM |
No crank 2003 C240 v6 sedan
Hi everyone. I have a problem starting my car. 2003 C240 v6 base sedan. First off I all happened about a month ago. The engine wouldn't start however it was turning over just not starting. Now it won't turn over at all. I checked all of the fuses,good. I tested all of the relays,good. Changed the starter relay on a hunch, nothing. Pulled the alternator and battery and had tested at auto parts store,good. Changed the crankshaft position sensor,nothing. I noticed when I charged the battery it read 11.98v and when I installed it after one crank I tested it again and it read 6.20v. Bought and installed a new battery, nothing. Changed the oil, nothing. Bought a new key from Mercedes, still nothing. Looks like the trunk has been leaking water around the fuse panel area as well as a little bit under the hood. It sounds like I can hear the starter click once but now it doesn't click at all. My tranny went out on my truck now both of the vehicles we own are immobile.
