Mercedes Benz Forum Help & Suggestion Center Have a suggestion to better Mercedes Forum? Need help with a feature on Mercedes Forum? Post here.
E320 no crank
Old Mar 7, 2016 | 04:38 PM
Morvic's Avatar
Default E320 no crank
Hello, I have a Mercedes e320 and I was driving when I noticed smoke coming from the hood. I pulled over and turned the car off myself, looked under hood and noticed the tensioner pulley broke. Obviously this is an issue being the belt was just sitting in on the rest of the pulleys. I immediately jumped in and tried to start it, nothing no crank. I recently had the starter solenoid replaced. Being that I turned the car off I'm confused why it will not crank with a new belt and pulley installed. Could it be the starter itself or is it some kind of safety mode because the car was running without a belt.
Old Mar 7, 2016 | 08:56 PM
chassis221's Avatar
The belt broke off so the alternator is not charging the battery. As soon as the belt broke off the battery charge light should have come on the steering would have also gotten stiff. Is the battery just dead?
Old Mar 8, 2016 | 05:52 AM
Morvic's Avatar
Battery is fine, even then the car never died out, I would have been able to get a crank out of it. I turned the car off the minute I heard the problem,and one minute after that I tried to restart it, no crank. Is there anything that could stop the car from starting after it was running without tension other then a bad battery.
Old Mar 8, 2016 | 07:25 AM
fasttee's Avatar
Have you had the ignition switch checked?
Old Mar 8, 2016 | 07:49 AM
Morvic's Avatar
As for the ignition switch I feel my problem is related to the car running without the belt tension for the minute it was. I never had a problem with it starting. Is there any sensor on this car that will burn out due to the car running without tension.
Old Mar 8, 2016 | 02:49 PM
Morvic's Avatar
Battery is testing perfectly fine,could it still be the reason it will not crank, I keep hearing that the k40 relay could be the issue,is that possible. Could it be that when the tensioner broke the relay burnt out. Is there any other relay or sensor that could have fried in result??
seensee
Jan 4, 2014 07:22 PM
David Stott
Aug 3, 2012 05:16 PM
billt2
Oct 13, 2011 04:33 PM
ar1217
Mar 1, 2011 06:21 AM
bm37
Jun 26, 2008 04:58 PM
