Mercedes Benz Forum Help & Suggestion Center Have a suggestion to better Mercedes Forum? Need help with a feature on Mercedes Forum? Post here.
Manual swap 2002 call 430
Old Dec 13, 2018 | 07:46 PM
dmclk430's Avatar
Default Manual swap 2002 call 430
Hello... I have 2002 CLK-430 I’m looking to do a manual swap currently car is auto and I would like to do a swap with manual transmission... any suggestions or point me in the right direction... I want someone/shop to do it for me...
Old Dec 20, 2018 | 02:39 PM
PelicanParts.com's Avatar
Hello and welcome to the forum! Where are you located? There are a lot of threads and info about this online. Any indie MB shop should be able to tackle this project, but it will not be cheap.
Old Dec 21, 2018 | 08:37 PM
dmclk430's Avatar
thank you for responding... I figured it wasn’t gone be cheap... I am located in southern Jersey cherry hill area... I have local shop that probably can do it & that same shop maintains both my benzes my 2008
E63-AMG & my 2002 CLK that’s all they work on is German cars & they are very good & reasonable prices... I never asked them if they can do but I’m sure they can... out of which Mercedes should I use the manual transmission or is there complete kit out there that I can get to do a manual swap... please let me know or do you have the parts that I would need... thank you...
Old Dec 27, 2018 | 03:18 PM
No problem, glad to help out. You would likely want to find a second generation manual CLK and grab the trans from there. I believe the CLK was also based on the C Class, so perhaps a manual C class would work as well. Your mechanic would have a better idea of what would work and fit. Hope this helps and best of luck!
queen
Jul 31, 2008 05:00 AM
127.72 MHz
Oct 25, 2007 08:04 AM
TreeTopsRanch
Aug 8, 2007 06:05 PM
yeravgjoe
Dec 30, 2006 10:58 PM
