Mercedes AMG Class All AMG Models.
Loud Squeak
Old Oct 3, 2006 | 01:10 PM
supdon's Avatar
Default Loud Squeak
I recently adopted an '04 E55 and there is a loud squeak from time to time when I take off. Has anyone ever experienced this. Car is under warranty but dealer is giving me the run around saying this is normal. They also recently replaced the power steering hose. Initially the service rep said it was the turbo but I know turbo's, they wind up like a top not squeak. Any input will help
99 E320
01 CL500
04 E55 AMG
Old Oct 3, 2006 | 01:22 PM
I8A4RE's Avatar
Default RE: Loud Squeak
My 03 S55 still does that. I had my rear axle replaced under warrenty and it stopped for about a month. It is doing it again and seems to squeek when it changes from 1st to 2nd gear. I could never get anyone to tell my why. I have just decided to live with it. I have found that in sport mode it does it less. I also found that it tends to do it more at mid throtle. So if I don't want it to make that noise I either very lightly push the gas pedal down or push really hard. Sorry I couldn't be more help.
Old Oct 3, 2006 | 01:57 PM
chiromikey's Avatar
ORIGINAL: supdon
99 E320
01 CL500
04 E55 AMG
if your service rep said it was the turbos you need to find a new dealer...QUICK!!! how the hell could a mb rep not know these cars don't have turbos???
if your loud squeek is typically only right after take off and is associated with a little surge in accelleration it is most likely the supercharger clutch engagement. although annoying, it is quite common, and shouldn't cause any other problems. mb is fully aware of this and typically will add/remove a shim to the clutch pack which ussually solves the problem for about a week. '06's have a new s/c clutch pack that seems to have cured this issue but not many have had any luck getting an '06 clutch pack installed under warranty in their earlier model car. it's definitely worth a shot since it is the only solution that seems to work.
Old Oct 23, 2006 | 03:56 PM
supdon's Avatar
Thanks for the input. The squeak was due the supercharger clutch engaging and I also got a second opinion they stated it was normal for that year of vehicle.
mrcoyote
Sep 5, 2019 10:54 AM
rugger1
Oct 28, 2006 07:25 PM
EOLAW
Jul 30, 2006 11:03 PM
seitz729
Apr 21, 2006 03:14 PM
anotherchris
Mar 2, 2006 03:50 PM
