Water falling out the pump!
Old Mar 11, 2005 | 09:40 AM
dialup_2001's Avatar
Default Water falling out the pump!
I have a L Reg 180E and I noticed a overflow pipe??? coming out the water pump and going down the left hand side of the engine to the level of the sump (when looking at headlights) Why is water trickling out this pipe and what is it for???? Thankyou in advance
Old Mar 15, 2005 | 11:18 PM
Randy's Avatar
Default RE: Water falling out the pump!
Until a more-experienced person provides better information: in general, the tube is to carry away the small amount of leakage of coolant from the water-pump seal; I understand "some" leakage is normal.
I will leave it to more experienced people to define "some", etc.
Old Mar 16, 2005 | 03:53 AM
sleepwalker's Avatar
loose bearing, broken seal.
replace it now.
Old Apr 10, 2005 | 06:47 AM
SL600_Cruzin's Avatar
Whatever you do, DO NOT let it overheat, as you could blow the head gasket. Then you'll be into it for a lot more money than just a waterpump.
pseverin
Mar 15, 2009 08:01 AM
YuCrew
Jan 3, 2007 09:25 AM
kanio
Sep 15, 2006 04:25 PM
filip75
Jan 20, 2006 12:36 PM
ska
Jun 11, 2005 11:15 PM
