valve cover gasket torque specifications
Old Feb 1, 2005 | 08:34 PM
az300e's Avatar
Default valve cover gasket torque specifications
I have a 1987 300e with the 3.0L. I am replacing the valve cover gasket and want to know how much to tighten the bolts.
Old Feb 1, 2005 | 10:15 PM
sleepwalker's Avatar
Default RE: valve cover gasket torque specifications
10Nm
Old Feb 2, 2005 | 12:30 AM
az300e's Avatar
Sorry Im not real technical, how may foot pounds is that?
Thank you for your response.
Old Feb 2, 2005 | 01:47 AM
http://convert.french-property.co.uk/
Old Feb 4, 2005 | 09:09 PM
az300e's Avatar
Is there any specific order you need to tighten down the bolts? From front to back or side to side, or a star pattern?
Thanks again
Old Apr 10, 2018 | 02:06 PM
yogib37's Avatar
Default torque specs
You would not use ft. lbs you would use inch pounds but if you did get ft lbs you can divide by 12.
But for inch pounds 10 newton meters equals 88.5 inch pounds.
here is a site that will help you
https://www.convertunits.com/from/ne.../to/inch-pound
sal911
Sep 19, 2010 11:05 AM
Steve's
Mar 16, 2010 07:08 PM
highsiera
Jul 13, 2007 09:40 PM
bchengwa
Apr 9, 2007 12:45 PM
76450SL
Jan 19, 2005 10:23 AM
