Vin Decoder
or
Login with Facebook
Transmission fluid
Post general Mercedes Tech questions here.
Transmission fluid
09-02-2005, 08:21 PM
NICKSPA
Transmission fluid
Is Dextron III the correct fluid for my '91 300E? How many quarts does it take to change trans fluid if I drain the torque converter?
NICKSPA
Find all posts by NICKSPA
09-03-2005, 04:46 PM
shooter
RE: Transmission fluid
The dextron fluid is fine. Start with 4 qts, start the engine and add 2 more and check it . Should hold about 7 qts with a converter drain.
shooter
Find all posts by shooter
09-06-2005, 12:20 AM
NICKSPA
Thanks for your help.
NICKSPA
HELP!!! powersteering fluid in Brake fluid container
liquid_drop
04:19 AM
Transmission Fluid
C280 wizard
10:48 PM
Auto Transmission Fluid and Filter Change
handyjay
06:11 AM
Changing Transmission Fluid
Buck
09:30 PM
transmission fluid
truespin201
11:09 AM
Tags
300
300e
converter
drain
fluid
mercadies
mercedes
quarts
take
torque
transmission
replacing dash
Posting Quick Reply - Please Wait
Quick Reply:
Transmission fluid
The following errors occurred with your submission
Okay
Quote message in reply?
10:43 PM
