steering play compensator
Old Jul 23, 2005 | 02:31 PM
Oreo's Avatar
Default steering play compensator
Hi
I was going thru the 124 MB service manual (46-0325) for the steering box and came across a section on the steering play compensator. This is different from the 19mm nut with 6mm hex that I'm familiar with. The manual says that this compensator only works in the straight ahead position. Can anyone explain what this is and how it works? Is it supposed to remove all free play? I'm tempted to remove mine to have a look inside as per the instructions. I have about 1cm free play that I can't take out with the 6mm hex. Also there is a very faint knocking coming from the steering box that I can feel more than I can hear when I jiggle the wheel. Can the play compensator help me?
Oreo
92 124 200E
Old Jul 23, 2005 | 08:25 PM
bazzle's Avatar
Default RE: steering play compensator
From what Ive seen a slight knock heard when car is stationary and engine off if a common trait on most MB rec *****. I wouldnt worry unduly about it.
Mechanic told me it is due to normal wear on most used parts in box. Tightening further will make it tight off centre.
Bazzle
Old Jul 24, 2005 | 10:31 PM
Tishers's Avatar
If I recall correctly when you adjust the free play in a recirc ball steering system you are actually increasing-decreasing the lash between gears. Either through a wedge that jams between the gears or by forcing the gears closer together.
You could crank that all the way down and have no free play at all but then it's also going to be very stiff steering. This will also cause the recirc ball mechanism to wear even faster.
Old Jul 27, 2005 | 02:43 AM
Oreo's Avatar
Hi All
Thanks for your replies and advice. I managed to trace the knocking noise to a loose tie rod joint at the furthermost joint. So it was not so perceptible to me at first. Got that replaced. I still have about 5 mm or so free play in the centre position. So I think I might go under that take out that play compensator to see what it does. There's a pin and spring in there that's supposed to put tension in the gears at the centre position. We'll see.....
Oreo
norton
Oct 28, 2012 10:01 PM
tommy2toes
May 1, 2010 04:44 PM
ADB
Jun 22, 2007 10:06 AM
Gold3DT
Jul 20, 2005 09:57 PM
lukeo4
Mar 3, 2004 04:10 PM
